Hello,
I have a Troy Bilt lawn tractor with a 17.5 OHV Briggs Stratton engine. First start of the day (doesn't matter if it is morning or afternoon) it is very very hard to turn over. I have checked the basics like battery, spark plug, airfilter for clogs. When I turn the key it wants to turn over but instead the cylinder may move a half stroke then it stops. If I hold the key on the starter gets so hot it will smoke where the main hot wire connects. I put my car starter on it to see if it would make a difference and it did nothing. Someone told me that it could be cylinder pressure????? Can this be adjusted if there is such a thing? I am at the conclusion thus far that it is the starter. Can someone please pin point this problem for me.
