Repairs PM260z Kohler CV740 throttle linkage
fmorelli
Hi all, hoping someone can help. I disconnected my throttle linkage during a repair and did not snap a photo prior. While I have all the factory manuals, none discuss the throttle linkage. Of course it is unique to this series of motors. Mine is specifically the 992047 model with the 27HP Kohler engine (non-EFI). I'm specifically looking for a photo of the connection from the throttle cable to the cadmium plated linkage which connects to a vertical shaft. There is also the throttle plate linkage that comes up from underneath which I believe connects to the same linkage plate as the throttle cable. I also believe (but am not sure) that the throttle plate linkage is supposed to have some kind of snap-lock to hold it in place?
The part I need connections to is #10 in this diagram:
partstree.com/parts/kohler-engines/engines-vertical/cv740-0026-kohler-cv740-engine-command-pro-mtd-cub-cadet-27hp-20-1kw/engine-controls-9-24-396
Any photos or assistance is greatly appreciate.
Filippo
