PLASTIC GAS TANKS / J D HOOD REPAIRING
Boobala
Here's a few videos about fixing your leaking gas-tank, or a plastic hood ( and other items too) ..... you can get away with using an inexpensive heat gun, and using material from other discarded tanks or buying the same type material "welding-rods" it's most important to use the same type of plastic you're repairing, you can also use alcohol or acetone for final cleaning BEFORE repairing your item, heat-gun nozzles are available on-line........
https://www.youtube.com/watch?v=Lqu3NVqFNCU .......... ( important to see ENTIRE VIDEO )
https://www.polyvance.com/Polyethylene-1/R04-04-01-NT/ .... ( navigate all over this site, ... good info )
https://www.polyvance.com/John-Deere-Lawn-Tractor-Hood-Repair/ ... ( John Deere Hood Repair )
NOZZLE.JPG..NOZZLE B.JPG..
