Photo of CC800 Throttle Control Bracket Assembly?
misterpants
  • / Photo of CC800 Throttle Control Bracket Assembly?
I bought a used CC800 and the PO replaced the carburetor. In the process, he either forgot to take photos of the throttle cable assembly area with the governor spring or lost the actual spring. As a result, he jury rigged a spring to a random spot on the frame. It works okay, but I have ordered the OEM springs but it is not clear to me where they connect. Can anyone provide a detailed photo of the cable assembly area where the throttle cable is clamped and the governor is located? I am attaching a diagram of the area from a parts catalog.
Many thanks!
sgkent
there should be a button in a new thread where someone has to click that they have provided make, model and serial or equal before it will allow a post.
That is a MTD Powermore engine. Try contacting MTD at the following number as I don't have any on the T84 engine here so I need to call them too.
