I noticed you got no response in several days so maybe this will help:
Since this is a help forum, it is only fair that the people trying to answer questions have some information to work with, so they can give an accurate answer. This helps them if they need to research parts or service information on your engine or equipment. In the first part of your post please include your engine numbers from the ID tag or stamping and the equipment type and model numbers that are on it. Failure to do this may result in you not receiving any accurate help with your problem.
When this forum first started and was much smaller, it was common practice to post some information about the unit along with the question, but we've had a lot of new people join lately who seem to overlook this important step about posting (it is the first post in this section).
Many of the tech's that hang out here work in or have there own shops and the first thing they do when they make up a work order on a unit is include the engine and equipment numbers on the work order. Since this technical forum is offered free to the public, it's the least we can ask you to do, so please help all of us out.
And please turn of the caps lock, it means you are yelling.
