Variety of causes, so you are going to have to do some checking. Are all connection good and clean? Is the oil over filled? What is the battery voltage while cranking? What are the model numbers of the engine? Let us know and we will try to help.
Model is 31P777 0296 E1. Battery tested good. Starter good. Cleaned all connections. Oil good. Flywheel good. Haven't tested crank voltage, meter not working. next step.
Valve clearance is .005 inches for both the intake and exhaust. They should be set when the piston is 1/4" past TDC on the compression stroke. Set them, turn the engine over four complete cycles by hand, then recheck. It is not uncommon to have to do this once or twice to get it right.
