wickedgoodoutdoors
- Mar 22, 2011
- 20
- 56
Some are New Some are fresh water USED.
Parts for OMCs JOHNSON,Evenruide, Mercury , Force outboards and other boat stuff
Make me an Offer for some or the WHOLE LOT!
Email Me at WickedGoodOutdoors @Maine.rr.com com
QTY DESCRIPTION New/Used Price Ea. Extended Price
1 Teleflex SeaStar steering Hydraulic Helm Tel Part# HA5418. New$325.
3 "Water Pump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2"",Dpth. 1 1/4"" - 6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others. New$12 each
4 Johnson/Evinrude New Stainless Steel Steering arms for outboards ( Will fit other brands) New $50 each
1 Johnson/Evinrude Tilt Pins retainer Bars for Johnson/Evinrudes ( Will fit other brands) New$10 each
2 Johnson/Evinrude VRO hose & Pump & Sender New $95 each
1 Johnson/EvinrudeTRIM TAB 327640 OMC New$10
1 Johnson/Evinrude Zinc Skeg trim tab New $20
1 Johnson/Evinrude drive shaft New $75
3 Johnson/Evinrude #323664 Spline Gear New $75 each
3 Helical Lower unit Gear sets 340490 New $75each
1 Johnson/Evinrude New Rectifier/Regulator Kit #CD4 583110 9GR-0A New $150
1 Johnson/Evinrude New Rectifier/Regulator Kit # 395391 New$150
1 Johnson/Evinrude Ignition Coil Kit # 583737 New $75
2 Johnson/Evinrude Ignition coils #582508-0560-0A New $25 each
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 New $85 each
1 Johnson/Evinrude Voltage Regulator Kit # 173640 New $150
2 Johnson/Evinrude Timer Base Kit #583376 New $150 each
1 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs New $75
1 Johnson/Evinrude Water Pump Impellers for 85-150 HP New $15
1 Johnson/Evinrude Complete Water Pump kit for ? HP #391391 New $50
1 Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # New $50
2 Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge. New$130 each
2 Johnson/Evinrude Trim Indicator Gages New $50 each
1 Johnson/Evinrude lower unit Gasket #286279-2 New $20
1 Johnson/Evinrude Complete Gasket set #139300 fit 85 to 150 HP V4 motors New $50
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $10 each
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors New $6 each
1 Johnson/Evinrude Gasket # 359-317955-1 New$8
9 Johnson/Evinrude Gaskets # 194-321727-1 New $8 each
1 Johnson/Evinrude Gasket # 436-323459-1 New $8
5 Johnson/Evinrude Gasket # ???? New $6 each
1 Johnson/Evinrude drive shaft 85 to 150HP New $100
1 Johnson/Evinrude Clutch dog OEM #22683 OEM #319895 New $100
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New$ 100 each
4 Johnson/Evinrude 90HP-150HP Rod Bearings set New $50 each
10 Brand New Aite Valves for Inflateable Boats. New $25 each
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $10 each
Teleflex 18-3056 Impeller Dia. 3 1/2"",Dpth. 1 1/4"" 6 Fins NeopreFits Honda 75 to 150 and Mercs and others.New$17
2 Rubber Exhaust GasketsNew $10
1 Complete 90 Hp Gasket set # 139300New$50
1 Gaskets # 317914 New$6
2 "used OMC Stator #583669, #583672, New$50
2 "used JOHNSON/ Evinrude Stator #583669, #583672, New$40
1 Johnson/Evinrude Zinc TRIM TAB 327640New$20
2 Johnson/Evinrude fuel fitings New$8 each
1 Johnson/Evinrude set of new plastic engine throttle connector slides New$20
1 Johnson/Evinrude VRO Oil Tank with hose & Pump & Sender New$100
1 Fuel Fittings Set male & Female old style MercNew$15
1 Fuel Fitting Honda New$10
1 Fuel Fitting Suuzki New$10
Teleflex throttle/shift CABLES OMC Johnson/Evinrude NEW! Just $2 per foot. New
2 Teleflex Black 12ft t shift/throttle cable OMC New $15each
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude New$20 each
3 Teleflex Black 12ft t shift/throttle cable Merc/Mariner New $15 each
3 Teleflex Black 16ft t shift/throttle cable Merc/MarinerNew$ 25 each
1 Teleflex Black 23 ft shift/throttle cable MERCNew$30
1 Teleflex Black plastic steering wheel New$15
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor. ( May fit other brands)New$40
1 Plastic Pitot Tube pickupNew $5
2 Battery Rotary Switchs USED $20each
1 pair of Standard Battery to Engine Cables Used$25
2 Johnson/Evinrude electric fuel chokes Used $25
1 Johnson/Evinrude 90 hp Carburator Used $50
1 Timer Base Kit #583376 Used $100
1 Johnson/Evinrude Rectifier Blue Power pack no part #Used $85
1 Johnson/Evinrude Rectifier/Regulator # CD4 #583336 23IM-0A Black RectangleUsed$100
1 Johnson/Evinrude Rectifier/Regulator #5114-04 DT-4 G Alum Metal Rectangle 3 wiresUsed$50
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $85
1 Johnson/Evinrude pt/pt Relay Box with Cable Used $50
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $50
1 factory service manualfor Merc/Force 9.9 or 15HP outboard motor.Used$40
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $20
2 Stainless Steel Steering arms for outboards Used $40 Each
2 Stainless Steel Steering Coupler brackets Used $40 each
2 Johnson/Evinrude Ignition coils #582508-0560-0A Used $99 each
1 Johnson/Evinrude OMC Stator #583672 Used $75
1 Johnson/Evinrude OMC Stator #583669, Used $75
4 Johnson/Evinrude ignition coils Used $10 each
2 Johnson/Evinrude Flywheel Used $50 each
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $20
1 Johnson/Evinrude throttle/shift control Used $50
1 Johnson/Evinrude throttle/shift control, missing a few parts Used $25
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $20 each
1 Johnson/Evinrude plastic throttle shift handle with pt/pt switch Used $20
1 Johnson/Evinrude plastic throttle handle. Used$15
1 Johnson/Evinrude complete wiring electrical harness with lots of electrical parts from Johnson 90HP V 4 Used $100
2 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs Used $50
2 Johnson/Evinrude Tachometer used Used $10
1 LOWRANCE Blue water Pro Flasher/Paper chart recorder Fishfinder with transducer. Used $150
1 RAYNAV 520 Loran with couplerUsed $50
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $100
1 Raytheon VHF/TV Anttena Dome Used $40
1 ONAN Temp Gage #129-8739 desc: AK21LB23 New $100
1 ONAN Temp Sender #7E-4279 desc: AK 25EB33 New $100
1 Adaptor # 9M-6522 Desc: FITAM26 New $6
1 TEE # 033-2177 Desc: FITDP08 New$40
1 ONAN Fuel/Oil Filter New$10
Used
4 Factory & Aftermarket Marine Outboard Motor Repair Manuals Johnson, Mercury, Force, Subaru Used $10
1 pair Large indoor/Outdoor waterproof speakers used Used $40
1 pairSmall indoor/Outdoor waterproof speakers used Used $40
Used
2 Two Power tilt motors for older OMC I/O outdrive. Unknown condition need rebuild. Used $20
1 Bronze 11/2 Prop Nut Used $5
Used
1 Fuel Hose with Fuel Fittings & Primer old style Merc Used $10
1 Fuel Fittings Set male & Female old style Merc Used $10 $10
1 Johnson/Evinrude Fuel Hose with Fuel Fittings & Primer Used $5 $5
Teleflex throttle/shift CABLES OMC Johnson/Evinrude USED Just $1 per foot. Used
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner Used $12 $48
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner NEW $24 $96
4 Teleflex Black 16ft t shift/throttle cable Merc/Mariner NEW $32 $128
1 Teleflex Black 23ft t shift/throttle cable Merc/Mariner New $46 $46
1 pair of Alum/Plastic oars for inflateable boat Used $20 $20
1 Teleflex Marine Trident Blue Wet Exhaust Hose 3 dia X 50 lg. Used $50
20 Heavy Battery Cables 2 ft long with ring lugs Just $10. per foot Used but never outside.
1 Raytheon Marine Electronics Factory Service Marine set of 2 Used $40
2 Alum Dingy Davit Brackets NEW $300
TOTAL
Used
Used
Used
TOTAL
Johnson Evinrude Alum Propeller, NEW, 14 X 19 #176215, 13 splines.png428.2 KB · Views: 1
