Parting out 1989 M21ZMR
Sixer
Parting out good running M21ZMR, non injected 4.5 HP Commercial Self Propelled 3 Speed Bagger/Mulcher. Only bad parts rear drive wheels, tires split.
ENGINE-Complete minus carb and recoil, available separately. Runs perfect, minimal carbon, great compression, always run on ashless LawnBoy oil, no noises, great power, governor perfect, muffler and guard, mounting base, drive belt pulley included. $65.00
TRANSMISSION-All gears work, no noises, solid, disassembly and regrease would ensure longevity, but works fine as is. Wheel drive gears, thrust washers and all snap rings included. $75.00
REAR WHEEL ADJUSTER/BUSHING ASSEMBLIES-One almost new, other excellent condition. Includes mount plates and bolts. $40.00
CARB AND MOUNT BASE-Desirable Mikuni, perfect in all respects, clean and ready to work. $45.00
AIRCLEANER HOUSING, BASE AND COVER-With screws, filter, screen. Like new. $15.00
HANDLE ASSEMBLY WITH CABLES AND RECOIL ASSEMBLY-All cables move freely, throttle and shifter tight and accurate, recoil strong spring and positive engagement, includes cable attachment mounts at mower and height adjustment knob/mounts. $25.00
MAGNESIUM HOUSING-Includes front wheels and adjusters, bushings worn, good condition overall. Small crack in non-critical area, stopped with drilled holes. $35.00
BAG AND MULCH PLATE-Both in good condition. $25.00-SOLD
Freight extra, will use FedEx (discout rates) or USPS, depending on cost and buyer preference. Will respond quickly to all inquiries. Thanks!
