P220 G Broken Rod
lyclark
Hello. I need to know what engines will replace the P220G- I/11251G Onan on my 1991 Grasshopper or does anyone know where to find a rebuild kit for less than $1000?!!?? Any help or advice would be much appreciated. It is still in very good shape and I'd love to fix it. Looks like a used engine might be the cheapest way to do it? Thanks!
If it's only a broken rod, cylinder and crank good you should be able to fix for about $500.
