GFP is $155 plus with the coupon code it's 5% off I think.
You can get the gaskets individually IF you do not need ALL of them, but you would need to check the totals.
If you find the right supplier, you may be able to get these cheaper with Kawasaki part numbers but I have not had much luck doing this.
