Thanks
I need to figure out which are apples, oranges, peaches, plumbs, nectarines. grapefruit and tangerines.
Yeah, there are sooooo many good ZTR's on the market now that you have to try to be sure you are comparing similar machines across brands. Best rule of thumb is if there is more than a $500 or so price difference(the regular MSRP for any two ZTR's) they are probably apples and oranges. If they have similar trannies, same deck size & gauge and engine hp they are usually a good comparison. Of course you'll find a few with ZT-3100(considered entry-level Commercial trannies) where another has the ZT-2800(high-end residential "serviceable" trannies). Same with decks with 10gauge usually being on the high-end Residentials and 7gauge on the Commercials. For engines, Kawasaki's are considered the most reliable and durable on the small engine market but they come in FR series(Residential), FS series(Heavy Duty) and FX series(Commercial). Also, a full suspension seat is VERY nice to have on a ZTR because they ride a bit rougher than a lawn tractor. There's a LOT to consider when shopping for these machines and your head will probably be spinning with specs like mine was:0)
Take your time, look at & demo several and ask questions on the forums. You'll find the one that's just right for your needs and in your targeted budget. BTW, all of the machines you listed are decent ZTR's you just need to narrow it down to the one that has what's important to you on it and is a good deal.
