Older Craftsman Recoil shroud removal help
thadpk
Hello all. Trying to get to the recoil assembly on this old craftsman with a Tecumseh engine. It appears the assembly was riveted on. Was this the norm for that vintage? I would assume I am going to have to drill these out as there is no other way that I know to remove them. Any idea on what drill bit size would be needed? Thanks!
Just remove the entire shroud to get at the recoil.
