Hi, newbie here,
Bought a used Ingersoll 111 YT and it was running, but kept stalling out. So I did a carb clean and adjusted it and it was running great for 10-15 minutes then stalled out and wouldn't restart, just a clicking sound and the flywheel "wanting" to turn. I've had this happen twice now. The first time I thought it was the battery, so took it out, charged it and a reinstalled a week later (busy with other stuff) and it started up. This time the battery charge hasn't done the trick. What should I check (and how) in order of most likely culprit? Thanks.
