I am a retired guy who has been fixing small engines for friends and neighbors free of charge for many years I am usually 75% affective on units It's not to often I get stumped but I got 1 now that I need help and advice on THANKS in advance!!!!!
small older tiller engine that has NOOOOOO spark It was stored in a moist area for a few months but before that it ran great!!!! I have replaced points (gapped right), condensor, coil and plug wire, checked wiring, flywheel has no wobble is tight--- the only thing I have not replaced was/is the u shaped metal device that holds the coil (armature???) engine sits on a GILSON tiller -great little item and hate to trash it.
not sure how to check gap between coil and flywheel
have decent compression
TXAGAIN for any help direction etc. BOB
