Hello, I have a old (1980) wards riding mower with a vacuum fan system, rear center discharge that I am seeking information on. On the bottom side of the mowing deck it has two large fans located above the blade to assist the grass discharge... If anyone has a diagram of this spindle/fan assembly that would be a great help! I have search the Internet but haven't had any luck finding any info on this at all. The mower has had a hard life, so all the model numbers have been worn off or are unreadable, I found out the year of it by the engine serial numbers. It is a wards 11hp, 3 speed w/ reverse, vacuum fan system mower....
