Old Simplicity Soverign 3314H Won't Drive
tdowd95
I have an old Simplicity Soverign 3314h tractor. It was driving strong and fine until one day it just stopped and refused to move. Still cant get it running. Just put in trans fluid, it was low. Any help?
First thing i would check is the hydro release to see if it was pulled out by mistake. Second thing I would check is the drive belt. It may be worn or broken. When was the last time you changed it?
tdowd95
All the Mechanical Stuff is pretty foreign to me. Where is the release? I'm not too sure when the belt was replaced.
I just found it weird that it stopped all of a sudden
Release is on the back of the tractor. Look for a lever or rod that can be pulled out or pushed in. Should be in. Old belts will break or jump off easily. With the engine off the drive belt shoul be tight.
