I also agree with everything that Lawnboy77 says. The F series motor is one of the best motors that Lawn Boy made, but with age, certain things need to be done with them to keep them running strong. Seals, ports, and fuel systems will all need attention at some point. The good thing about an older Lawn Boy 2-stroke engine is that it is simple and easy to work on. You can also find most of the basic parts from a number of sources on the web. If they don't run right, it's usually a problem that is easily remedied and very much worth the time and expense. I have two Lawn Boys from that era and they run just as good as new. I have cleaned out the exhaust ports and replaced crankshaft seals on both of them, along with regular maintenance.Okay you have a nice F series mower from the late 70s or early 80s. Sounds like you have a fuel supply issue, probably just need to do an overall 2 stroke tune up, which will include, cleaning the carb, checking for good fuel flow from the tank, cleaning the exhaust ports and muffler, possibly replacing upper and lower crank seals. These 2 strokes really need to breath well and good seals, upper and lower, clean ports and clean exhaust are keys to getting a good flow of air through the carb venturi, without the proper flow of air and fuel mix through the engine, it will lose power and die. I think you can rule out ignition issues since it starts on a prime or two after it dies.
Very cool, I will check it out
I talked to a small engine mower repair shop and they suggested loosening the gas cap? to just try it. something about a vapor lock?
I re cleaned the entire carb again and started looking into the seals and things like that and ended up calling this shop who does work on old lawn boys. im not sure what that even means? loosen it? wont it keep spinning and sill gas?
should the little hole be clean? when i have mowed recently with a full tank the gas spits up and out of the little hole.
starting to get a little frustrated since I though I could have it fixed by now, and it wouldn't mow this weekend at all, same thing, starts fine, sounds good, mows for a couple minutes then just dies, prime it again twice, starts right up, same thing over and over.
well just found a used 7260D for 125 bucks, 21 inch,
https://pittsburgh.craigslist.org/grd/6098855287.html
or
7261 with a new engine
says all carbs and mufflers cleaned and blades sharp
which is better? leaning towards the new engine one but don't knwo anything about these, or years etc?
thanks!
