I am trying to find the oil sensor.
The mower is the older underpowered scag 48" rider with the 18 hp kohler Magnum vertical shaft.
I have the manual but the images are so poor that I can't make anything out. Oddly no mention is made of the oil sensor. On the manual for the horizontal shaft version of this motor the picture showing the oil sensor is clear and the thing is labeled. But no on my model
My oil sensor keeps shutting my machine off.
I want to remove the wire and either ground it or whatever to take it out of the equation. I could replace it but the mower is on it's last season.
It reports falsely shutting my engine down or not allowing it to start for no good reason.
Does any one know where the oil sensor is? I have a suspicion it's around toward the front where I can't see it.
Edit/Delete Message
Edit/Delete Message
