Oil leaking on deck of craftsman 6.75 lawnmower
larrywr
After replacing the belt with the lawnmower tipped backwards the lawnmower has leaked oil on the deck.
mechanic mark
Wipe off deck with shop towels, check oil level on dipstick and adjust to full mark. Check air filter for being oil soaked, replace if soaked. Always work on lawnmower with carburetor side up, mower on its side, or drain oil from engine & fuel valve in off position, or drain all gas & work on mower however you please, just remember to add oil to engine.
