I came across this forum looking for info on my 2006 Craftsman 24hp Intek,48" mower which was leaking oil. Still does, but I bought another Craftsman 26hp/54" so in no hurry to fix it. Still haven't found the leak source, but finally got the flywheel off, but the project is on the back burner now. Oil was coming down behind the starter above the oil drain tube (which also leaked and was replaced with a bolt) which had me confused until I replaced the drain tube and was still leaking oil. Any body know of a common place for the leak?
Doug
Doug
