Oil in breather chamber
Chadk0329
Hey, I am getting oil in the breather chamber of my push mower. I have the top of the mower taken apart so I can see inside the chamber. I have read some things, but I am at a loss for where to go from here. Symptoms:
Smoke coming out of air filter
Engine runs smoother without filter
Knocking sound
Any idea where I should go from here? It is a B&S 550E motor
Thanks for any advice.
mechanic mark
Check oil level on dipstick first, then call auto parts store & ask if they have a compression tester you can borrow. They will charge you a fee for rental & if you return tool in original condition you will get all money back. Sounds like you may have a blown head gasket, that is why you need to perform a compression test. Let us know how it goes, thanks, Mark
Post all numbers from engine, model xxxxxx, type xxxx, trim xx, code xxxxxxx.
sgkent
if this mower is important to you take it to a good shop. If it is not important to you, and you can afford to screw it up learning to work on engines then continue. I am not being condescending - just concerned that you lack the tools and experience to go on. But if you can afford to get it apart and make things worse then it will be a good learning experience, and if you succeed, you may even get a good running engine.
