blacktrain
- Sep 13, 2011
- 3
I have a 21hp Briggs Vanguard twin cylinder on a Simplicity zero turn. Model#385777 Type#0116-E1 Code#05082911 I am getting a large amount of oil in the air filter. Would this be caused by a bad head gasket? The valve cover with the crankcase vent and reed valve are new, because I thought maybe that was the problem, but after changing that I still have the problem. I appreciate your help. Thanks!
