What is the correct filter for Kaw FX801V on Lazer ZX. Will 49065-7007 work? Stated OEM is 7010. Dealer says 7007 will work.
#2
scott47429
the two numbers come up as different filters i had the 20 horse kawasaki and used a car quest R85394 and use the same filter on my Exmark with the 31 horse daihatsu engine in it much cheaper to buy the the exmark and works just as well i used it for 11 yrs no problems on the kawasaki engine its a toyota filter i just crossed the exmark number at car quest
My Exmark has the 801V. I use automotive filters in mine. Below are a couple of the ones that fit.
AC Delco PF53
Bosch 3311
Fram PH4386
Fram PH4967
K&N KN-128
Mobil M1-103
Motorcraft FL836 *This is the filter I use. IMO this is the best filter money can buy.
Purolator L14476
Purolator L14477
Below is a list of Kawasaki filters that cross with the OEM filter.
KAWASAKI 16097-1069
KAWASAKI 45065-2071
KAWASAKI 49065-2060
KAWASAKI 49065-2068
KAWASAKI 49065-2071
KAWASAKI 49065-2072
KAWASAKI 49065-2075
KAWASAKI 49065-2076
KAWASAKI 49065-2077
KAWASAKI 49065-2078
KAWASAKI 49065-7004
KAWASAKI 49065-7010
