oil changing
bikerman
Want to change oil in engine & the transmission on John Deere 332. I don't have a manual. I was wanting to know what you have to do to change the transmission oil. There is supposed to be a filter, and how to get to it? Also, the engine has a filter where is it located? Do you have to do anything special after adding the oil back in the transmission? Can you supply the numbers for the transmission, engine and the air filter for the 332?
Thanks!!
bikerman
That's ok, but it seems to be more about repair and rebuilding. I was kind of like wanting just some maintenance information on general upkeep of the tractor. Like access to filter on the transmission and filler location. I didn't know if that is in the owner's manual or not??
bikerman
I was wanting to find out on manuals a question I have. I have seen operator's manuals, and I have seen operator's & maintenance manuals listed for sale. Can you possibly tell me which one is the one that would be the manual for basically the normal work on the tractor servicing intervals. I have, also, seen technical service manuals listed for sale. I am not for sure what is provided with the tractors etc. I just got involved with this tractor, and want to be able to do the maintenance on it. I called John Deere and they tell me they can order manuals. I don't want to order anything I am unsure of that is not going to be of help! Thanks for any help you might be able to provide!
