Aloha all. Need to change my oil for my Kohler Commander 23, is it okay to use Delo 400, 15w-40? Or if not, what would be the best for it?? Not to sure, just bought it used with 534hrs. 04 John Deere L130 with Kohler Commander 23.
I think what I would do is contact the previous owner and find out what he used for oil first. Kohler engines recommends a SAE10w30 or 30 that Exceeds API service rating SJ or higher rating. You can use the Kohler oil if you can find it but any brand will work just as well. I've run Mobil Super 5000 10w30 in my Kohler Courage 20 &22 hp engines for years without any issues. I also use it in my Kawasaki FS and FX engines and I've never had any issues. If you use the Multi-Grade oil most manufacturers will tell you its use can increase oil consumption somewhat so check your oil more frequently when using a Multi-Grade.
