I did an oil change on my LGTX 1050 Cub Cadet mower and unfortunately it did not go well. I could not figure out the 1/4 turn quick disconnect and ended up unscrewing the entire quick disconnect from the engine (it was completely loose, I assume it was never properly tightened by the factory). Luckily the mower deck was off, but oil spilled all over (and possibly into) the electric pto. I've cleaned up all the oil I can without taking anything apart, but I'm wondering if:
1 - can oil have gotten into the electric pto?
2 - if so, is it a problem?
