Oil being sucked into the carb from the vent hose
Bruce1951
I have Kohler courage 20 engine, model #sv600s
I keep getting oil sucked into the Car from the vent tubing coming from the front oil pan, when it started this i thought it might been from having to much oil in the engine because it blew the vent hose right out of the engine's oil pan?? in the front. So I drained the oil and measured the the right amount oil and refilled the engine and put the hose back into the oil pan? or whatever its called and ran perfect. this morning I started the rider up and now it sucking oil back into the carb, I even took the air breather off and it stilled continued to suck the oil.
A few month ago I had a oil leak from the oil pan and took it in to a shop and they put a new Gasket on it to stop the leak.
I need to know if I should trash my rider or try repairing the engine.
I'm willing to bet you have a blown head gasket. Start the engine and run at 3/4 throttle. Remove the dipstick and let it rest on top of the fill tube. If it is bouncing all around, I would be replacing the head gasket.
