I finally got the drive belt in place!
Then I had to straighten a bent bracket and add two washers for a pulley to get lined up. Was able to get the motor running, I went for a drive and everything looks, feels and smells like it’s all good!
NOW I’m back to the motor won’t start!
Has my engine jumped out of time?
The motor starts to spin then I guess the spark plug fires, I hear a loud pop and the engine goes backwards. I hit the key and it will be spinning one way, but it’s like when the compression gets into the cylinder the engine turn slowly till it gets past that and then it’ll spin kind of freely till it hits compression again and it will slowly go past that. If the gas fires during compression it moves engine backwards!
Where do I start fixing this problem!
Lloyd
Lloyd
