Not sure how this works.
LeeG
I have a Toro/Wheelhorse 522xi that doesn't like to reengage the mower-deck after stopping it (or backing up) after it has been run for awhile ( and is hot). Any ideas?
If you have an electric PTO, it may have a hot short or open, by which I mean, the PTO coil is either shorting to ground or breaking open when it gets hot. After it cools down, it contracts, making a good connection and works properly again. I have also seen PTO switches do the same thing.
Briana
Toro Won't Re-Engage Mower Deck
Welcome to LawnWorld!
We moved your thread to the Toro/Wheelhorse forum.
LeeG
Sounds right. Any idea how to Find/Get to the PTO coil?
Thanks
The PTO coil is not fixable, would need to be replaced.
