Repairs not running
jeff60
I have a ferris pro cut z stopped running on me in the middle of mowing.only will run in the start position, replaced carb, air and fuel filter, pump, ignition switch, fuel, fuel lines, has spark in the start position only runs for tops 2 seconds after letting off the key. model pcz25k older model 70`s
