Noisy Z425 mower deck.
dblbogey
My JD Z425 mower deck rattles (metal to metal slapping sound) when lowered to the ground and traveling regardless if mower is engaged or not. It makes no noise when mower deck is up and traveling engaged or not. Any thoughts on where to start?
Gauge wheels wobbling maybe. You will need to lower the deck and then start shaking it to see what makes noise and moves when it shouldn't
dblbogey
Thanks for the response...mower deck wheels & hardware are good. I'd think the play would be in the lift linkage but I've added
a washer or two there to tighten that up. I guess I'll focus next on the belt tensioner arm & area. Thanks again.
