No Start
And what gender and species is this thing that the battery won't kick over.
helomech
You can jump across the contacts on the relay. Also check to see if there is any corrosion around the ground cable on the chassis.
Gravely Man
I took a good hard look under the seat and I found a tiny spade clip that was hanging loose and not connected to anything and I hooked it up and it started right off! Got a heavy rain so will have to wait a tad to cut my jungle grass! Thanks for all the tips. Adios until the next clarity. Glad I did not burn anything out in the electrical end of things with that high charge that blew the original battery out. Never had such a wonderful machine so I am getting acquainted now with it and love it.
