Problem now-Can noy start B&S 6.0 hp QUANTUM XTE- Engine used on CAMPBELL HAUSFELD STANDARD DUTY Pressure Washer 2200 PSI 2.0 GPM- Had just fixed sticking float in carb bowl. Engine would start, flood and stop before I had the sparkplug problem. After I fixed the flodding and tried to start engine, it would not start at all. I tried the sparkplug in another engine and it started fine. I replaced the same and new plug in the 6.0 engine and inserted a tester plug with a light mounted inside to show fireing if it occured. no light flashed. Tested the tester on another engine and showed to work fine. Removed the pull rope cover and flywheel to check the shaft key for alignment (no shear) which was ok. I can't believe it's the ignition when it was just running!
