No power to blue starter signal wire walker mt with Koehler 23 hp
kenneth2
  • / No power to blue starter signal wire walker mt with Koehler 23 hp
No power to starter signal wire when trying to crank. Checked 3 safety switches, all ok. Battery is good. Looking to find starter relay but can not find. Does anyone have an idea?
If this the correct wiring schematic then Relay A is the starter relay.
Attach PDF so the image can be blown up for clarity.
  • MT Service Manual-217.pdf
kenneth2
Thank you so much. Looks like I just need to find the darn relay to see if it is getting power to yellow wire
