ThatOneGuy1968
- Oct 3, 2023
- 10
- 32
Working on a Husqvarna 22v46, no crank condition..
The starter test bad to ground, I put my power probe on the starter and it pops my probes breaker..
The solenoid tested bad also..
Well I forgot to check for voltage on the two little wires so I put it back together and I have no voltage with the switch in the crank position on neither the switch wire or the coil wire to the solenoid
What Says You..
Cowboy..
What Says You..
Cowboy..
