LawnWizard
- Nov 17, 2021
- 13
- 85
2014 Hustler w/ FX691V. After replacing the longblock and reusing the fuel system, charging, exhaust etc. I developed an issue with cold starts. I didn't realize it immediately b/c I fully expected to use starting fluid on the first start. When using the mower daily the issue dues not appear, but after sitting for 3-4 days I need a small shot of starting fluid to start. The choke appears to be working full on to full off. It is required for the first start of the day as expected. The problem with diagnostics is that after the first start of the day, it starts fine thereafter UNLESS it's not started for 3-5 days. Is there something that would be obvious to someone that would cause this? Like I said, I get one shot at it till it sits for a while. Obviously the fuel is leaking back out of the lines, question is why and where to look for the cause.
Thanks in advance!
Thanks in advance!
