no firing
Let me repeat a post from another thread that might just get you the help you need. Please follow it.
Since this is a help forum, it is only fair that the people trying to answer questions have some information to work with, so they can give an accurate answer. This helps them if they need to research parts or service information on your engine or equipment. In the first part of your post please include your engine numbers from the ID tag or stamping and the equipment type and model numbers that are on it. Failure to do this may result in you not receiving any accurate help with your problem.
Many of the tech's that hang out here work in or have there own shops and the first thing they do when they make up a work order on a unit is include the engine and equipment numbers on the work order. Since this technical forum is offered free to the public, it's the least we can ask you to do, so please help all of us out. *So please post the numbers in the new topic you start to ask your question. It should be the first thing you write before beginning your question. :D
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
