newer cub cadet rider starts and dies (carb solenoid is not getting power)
jsjpn
  • / newer cub cadet rider starts and dies (carb solenoid is not getting power)
the carb solenoid is only getting power when cranking as soon as you let off the key the engine dies. some safety device is malfunctioning or relay isn't working? has anyone ran across this problem. it has a Kohler 16 hp command engine. with oil pressure sensor. any info would be greatly be appreciated.
BlazNT
Need the engine model number.
BlazNT
Also need Cub model number.
gspald
Been having similar problem with my Cub Cadet 2166 with same Kohler engine. Engine starts then immediately dies. I am not sure yet; but, I believe the Ignition Switch may be the culprit.
Fish
Could be, but having the schematic is always nice. As well as all of the model/spec numbers off of everything.
