Scottlarson737
- Mar 17, 2013
- 1
- 3
Hey all,
I purchased two lawn mowers this spring (just barely). One was a JD F510, the other was a JD F525. The F510 is running great, while the F525 has some axles that are completely locked up. I have every intention of trying to fix the 525 myself . . . just running through some diagnostics right now. So far here is what I've found:
1.) Oil level is fine and oil is like brand new.
2.) lawn mowers came from a tractor buff . . . they were taken care of.
3.) When jacked up, I can turn one wheel and the other goes in the opposite direction. Also, when I activate the hydro, forwards and reverse, no power to the wheels.
4.) Freewheeling "mode" by pressing the freewheel button is ineffective. Axle stays locked up.
5.) Brake is positively disengaged . . . I removed the linkage and moved the actuator with my hand.
6.) Hydro linkage is also disconnected and I am going in reverse and forward with my hand.
Next step is to drain the oil and split the engine from the tranny. I've heard that there can be a problem with the transmission output shaft bearing. Any insights or comments are welcomed.
Scott
Scott
