Newbie saying hello, need advice also.
scpopatop
Have been musing around on the CC site. I note first of all there's no bashing or smart alecks when a question is asked. That's commendable and different from a couple other sites I visit...Kudoes.
I just bought a CC rzt-s42 and pretty much happy with it. I'd wanted a single blader, but none to my satisfaction available.
Now to my quest for help. Mowing slowly, as along a fence line any time I touch the steering wheel left the mower will surge forward. Also when parked with wheels straight ahead, parking brake off, engine running slow, if I touch the wheel left the mower will move forward. Moving the wheel to the right the mower remains in place. Also, I sense the steering to the left is harder than to right. Tire pressure is same side to side, only 7 hours on meter, all I've done is changed oil/fil., lubed and adjusted deck. Have not hit any objects.
Could this be a simple adjustment or is it time to take to shop...40 miles one way.
TIA,
Jim
BlazNT
On my mower its called return to neutral adjustment. You will have to follow instructions in manual unless its new then off to repair shop.
scpopatop
Need advice re. steering on a RZT-S42
TIA,
Jim
TTT 1 time.
