If you get the Recycler instead of the Super Recycler get it from a dealer or at least go visit your service center. Before leaving the parking lot at Home Depot look it over real good. Make sure the adjustment levers are there, not bent, not broken, and really will lift the deck. Check to see if the wheels are tight, and they all look the same. Then look the mower from the front to see if the front and rear wheels are in line and all are setting on the level concrete when adjusted to the same height. Look for any missing parts anywhere. Look in the bag for trash or holes. Look in the gas tank for trash. Look in the oil fill for trash. Make sure the instructions and oil are there and the oil is sealed. If there is any grass clippings on it anywhere do not buy it. If any wheel wobbles, do not buy it. Make sure the air filter is indeed there. Make sure the cables are there. If there is a dent or a scratch into the bare metal do not buy it. Before even looking at one at Home Cheapo go outside and find the pile of wrecked or broken lawnmowers. Look them over real good and try to figure out what happened to them. Then go to the nearest Toro dealer and buy one from him.
