Lakeflambeau
- May 19, 2013
- 5
I received a hand me down Lawn Boy Model 10515.
I have a family friend mechanic look at it for me, so I completly
trust his work.
He said the Engine brake cable is very sticky.
He was able to pull the cable by hand using a wrench, and
the mower ran fine.
Only way to stop the mower was pull the plug wire using insulated plyers.
The other problem going in was the Traction control cable needs to be replaced.
So is there anyway to fix this engine brake cable?
Not sure if it is kinked or maybe rusted inside?
WD 40 or oil it possibly?
I think it has plastic wrapped around it.
Was thinking maybe stripping the plastic off and try
and soak it with WD40 or some other thing like that.
I guess I am cheap, but the replacement cable for the engine brake
is around $50.
Traction control is much more reasonable, and this cable has to be replaced.
Thanks in advance for anyones help for a newbie to this board......
trust his work.
the mower ran fine.
is around $50.
