Export thread
New to forum, need help identifying 3.5 hp B&S engine from early 70's
#1
U
ukwildcat53
I have a B&S 3.5 hp engine that I purchased on a mower in the early 70's. There is no identification on the mower as to series or model number. The engine was on a Toro mower which I want to use but I can't find an engine that will fit the mounting holes on the deck so I am interested in repairing the B&S engine but without a model number I don't know what parts to order. Any help would be appreciated. Thanks
#2
U
ukwildcat53
I forgot to mention this is a vertical shaft engine.
#3
BlazNT
BlazNT
Pictures sure would be nice.
#4
U
ukwildcat53
Here are some pictures.P1010006.jpgP1010003.jpgP1010007.jpgP1010004.jpgP1010001.jpgP1010005.jpgP1010002.jpg
#5
BlazNT
BlazNT
#6
U
ukwildcat53
BlazNT. Thanks for pointing that out. I couldn't get a picture that showed the numbers but they are as follows:
92902
1318-03
73042404
Now it is just a matter of finding parts.
Thanks,
Gary
#7
BlazNT
BlazNT
#8
primerbulb120
primerbulb120
When looking up parts for these older Briggs engines, you need to add a "0" before the model number. Also, leave off the last two digits or replace them with "99". None of the parts sites worry about the last two digits, apparently they're not necessary for ordering parts.
092902-1318-(99)
Now see what you can find.
#10
U
ukwildcat53
Thanks for the info and the parts sites. It will be great to get this engine running again.
