Mini Motors
- May 11, 2011
- 226
Rubber pieces more than plastic. The common complain over the years with ethanol has been that it eats away at older types of o-rings and some diaphragms/gaskets.
But back to the OP's original comment. It does sound like that guy wants to sell you a new unit. And while there is a difference between a Honda you get at a big box store and one you get at a true power equipment dealer, the difference is in the body, not the motor.
And I think your problem might be gas related, just not ethanol. I only put name brand gas in anything I own. Sunoco, to be exact. (*) And even name brands can be not so good. My son had trouble with Shell gas in his car. And while Sta-bil is a decent product, nothing beats just running it dry at the end of the season. Another thing I do is to run Sea Foam in everything all year long. It does some of the things that Sta-bil does, and helps to keep carbon deposits down, something that is a bigger problem in these air cooled(higher temps) and higher revving(2 stroke trimmers,chainsaws...)engines.
(*) Probably a comment for The Front Porch, but I chose Sunoco because it doesn't come from the Middle East.
