New hustler raptor SD 54 with bagger issue
Chasenfeathers
Hey guys new to this site and just got my first Hustler this morning. Mower cuts great very happy. I'm having issue with the bagger tube clogging I know it happens but any tips on how it can be managed? Have some buyer remorse on the bagger system.
Thanks in advance.
kraky
I have no experience with a hustler bagger but I do with others and in general with a cut n thrown system you can't be going any lower than about two and a half inches cut height or you won't have enough airflow to push everything up. Cutting no more than one-third to one-half of your grass height in a pass is also a good idea.
All this assuming you have the high lift blades on your bagger.
turboawd
did you change the blades? i thought the bagger requires higher lift blades for more blowing power.
Chasenfeathers
Hey guys,
I have the hi lift blades on. Ran it yesterday my problem was deck to low not allowing enough air flow. Plus my mowing speed was a little high. This is my first zero turn and they only one I've ever drove, learning as I go Now I just wish that the bags were bigger lol.
Thanks
