New guy with question
Grassmuncher
I have a 729 that seems to be starving for fuel. It's usually ok until it warms up, like after an hour of solid mowing. Then it will start to stall a little and eventually start stalling completely. It will run at lower rpms. It almost seems like a vapor lock or something. Thanks for any help, this is driving me crazy.
Used again today. It was about a 1/2 quart low on oil so I topped it off. On another post someone said a low oil sensor could cause these symtoms. Worked great for quite a while but then would stall when I would make quick turns and then return to normal or I had to back off the throttle a little for it to recover. I also didn't use the bagger or dethatcher today so the engine had less load. Any thoughts?
Could be your fuel pump or carb is gummed up
Sent from my iPod touch using LMF
