GrassAttack
- Jun 23, 2013
- 2
Hi everyone new guy from East TN checking in. I am just starting out on the commercial side of mowing and have a HD45 48" cut walk behind hydro, and use Stihl power tools. I have a few questions to ask about my mower from hopefully a skilled JD guy. The engine is a 14hp Kaw and it's leaking oil right above the oil drain where the engine splits. Is this the oil pan and how can I fix it? I have another 14hp Kaw, should I just bolt it on? Also the engine is pull start but the deck is PTO and right now I'm using a stand alone battery to engage the PTO for the blades. Does this motor have a charging system on it that will run the PTO? Thanks in advance and glad to be here. I am also a member at other lawn forums and would like to share what knowledge I have when possible.
