All tests have determined governor gearBasically yes, but I suggest you get the proper manual. A governor problem on one of these is rare unless someone made the wrong adjustment while tinkering. Governors are not an adjustment to play with for running problems.
What is actually going on with your engine before you go on this adventure?
Do you by chance have repair manual forBasically yes, but I suggest you get the proper manual. A governor problem on one of these is rare unless someone made the wrong adjustment while tinkering. Governors are not an adjustment to play with for running problems.
