Neutral On A Zero Turn
busa2000
I'm brand new to the zero turn world and read that when it's cold the Kohler motor tent to not start. If this happens can you move the mower without it running, meaning to the other side of the garage.
Scrubcadet10
Moderator
Staff member
If the engine has a choke, use it when first starting, or if the Air temperature is cool.
My cub cadet has the Courage 19, it's starts like a top even when it's 40F outside...if course in Texas days of 40 degrees are few and far between...
But yes, as long as it is neutral, or the handles are up i believe it should roll.
7394
Read your manual, on a Z, you will have to push in or pull out 2 pins in back behind the hydro trannys, to let the hydros roll. Hydros have no neutral, just stop, Go, & park
But your manual will tell you exactly on yours.
busa2000
Thanks for the replies, I got the unit used so I don't have a manual yet.
gainestruk
On my 18 hp on my gravely, I need to move throttle all the way to choke spin till it fires and dies then move throttle all the way down to idle it will then start and keep running, it's been like this from day one, if you haven't already replace spark plug and air filter, this will go a long way in helping you get it running.
7394
Many times you can find an online manual, No cost. Just google it up & see.
