Needing model identification help
bartles
The stamped model information on the rocker arm cover is no read able butvI have a photo of the serial number attached
Thanks in advance,
bartles
31C707-3346-G6
bartles
Got the cover off and carefully uncovered another model number....the serial number I provided initially was from the fan cowling. Probably not the original cover. Hopefully I can attach a picture...the letter after the two numbers "looks" like another number.
bartles
The pic up load didn't up load😖
The first two numbers are 28 the next "number" looks like a 2....the balance of the digits are H07-0196-E1. Could the digit after 28 be a Z?
282H07-0196-E1 would be a valid model number.
